dry gas
i think i got some crappy gas last time i filled up. car ran like complete crap. its runnin better now since ive filled up again but i want to run some dry gas through it? anyone know where i can get some? thanks
ORIGINAL: redass02gt
dry gas > wet farts?
ethanol = E85 gas.
ethanol = E85 gas.
Regular gas = small amounts of ethanol. . . . . but a lot of stations have gas that has no ethanol or "clean gas"
oops, my bad. what is the stuff that is like 10% ethanol and 90% regular gas called?
ORIGINAL: H0SS302
lol what the hell is dry gas?
I use the alcohol based ones, not the ethanol based ones.
I mostly use it if I find out I got watered down gas, or if you live in the colder climates it is used to put in your tank when you know it is going to get well bellow freezing so that it helps get rid of any moister in the system so that it dosn't freeze up causing start up problems.
You can get it most any store.
Lynn
