Automatic trans. question
Old Nov 27, 2007 | 09:39 PM
mustangcat's Avatar
mustangcat
Deputy CatDog - To Purr'tect and Explode
Default Automatic trans. question
On my grandpa's Automatic Durango you can shift it like it's a manual without any problems, it even shifts up for you while your driving(if you start in 1st gear, and you reach like 16 mph it moves the shifter to 2nd, and 3rd and finally drive).
Can my 2000 Mustang GT be shifted like a manual...1...2...3...D without any risk of damage?
Or can it shift up automatically like the Durango?
I'm cautious to test it out myself because knowing my luck, I'd break the transmission, rear end, and the cup holder all in one mistake.
Old Nov 27, 2007 | 10:09 PM
mustangcat's Avatar
mustangcat
Default RE: Automatic trans. question
Bump...
Old Nov 27, 2007 | 10:16 PM
blstoff's Avatar
blstoff
its ok to manually shift the 4r70w but not the earlier AOD's .
the shifter will not move itself but you can shift it manually from 1-2-3 . dont do any WOT shifts into or out of OD or you will destroy the OD band .
Old Nov 27, 2007 | 10:27 PM
Aereon's Avatar
Aereon
you will be fine shifting manually. If you plan on doing this alot, I would recommend a tranny cooler tho.
mustangcat's Avatar
mustangcat
Ok! Cool. Thanks guys!
Old Nov 28, 2007 | 06:43 AM
scfd524's Avatar
scfd524
I do it quite often on mine. It has 84k miles and I just had it flushed and inspected and the tranny shop said everything looked just fine. By the way, if you get on it pretty good and bump it from first to 2nd about 4000-4500rpm it'll bark the tires nicely. I don't bark the tires that way very often but once in a while when I feel the need or have some ricer behind me.
Old Nov 28, 2007 | 03:11 PM
dubarado's Avatar
dubarado
I shift my manu... ERR... I mean automatic all the time lol... WHen I go WOT and go from 1-2 my tires break loose... it doesn't do that when i leave it in D... and when I DS I just match the revs when I downshift so it doesn't jerk on the transmission.... it's a 4r70w BTW...
Old Nov 28, 2007 | 11:55 PM
radaman's Avatar
radaman
ORIGINAL: mustangcat
U can shift it all u like, but u cant out shift the computer and u r not going to gain any et's by shifting it manually.
Old Nov 28, 2007 | 11:58 PM
2k1gt's Avatar
2k1gt
You have a 3? I want a 3!
Old May 25, 2008 | 09:34 AM
grogan's Avatar
grogan
i have 1,2,d then that crappy automatic overdrive....
+1 on i want 3 too!!!
