nitrous
Old Nov 28, 2007 | 11:27 PM
meandmypony1's Avatar
meandmypony1
Default nitrous
does anybody know what size fuel and nitrous jets i should use to make a 150 shot i cant seem to find any info on what sizes to use
Old Nov 28, 2007 | 11:28 PM
mylongvictor's Avatar
mylongvictor
Default RE: nitrous
I think the kit tells you what size shot the selinode will do.....
Old Nov 28, 2007 | 11:31 PM
meandmypony1
Default RE: nitrous
i got a zex kit i bought used so i dont have the paper work and cant find it on there sight either
Old Nov 28, 2007 | 11:46 PM
01snake's Avatar
01snake
Default RE: nitrous
contact zex?
Old Nov 28, 2007 | 11:53 PM
meandmypony1
Default RE: nitrous
guess thats my only choice
Old Nov 29, 2007 | 12:03 AM
ZW99GT's Avatar
ZW99GT
Default RE: nitrous
The ZEX kit #82217(99-04 GT kit) is 67N/38F with 5 degrees of timing retard.
That is with 950PSI bottle and 40PSI Fuel.
Old Nov 29, 2007 | 12:08 AM
99gt302's Avatar
99gt302
Default RE: nitrous
http://www.zex.com/Products/JetCharts.asp
All sizes for 4cyl, 6 and 8 there...It came in handy when I but the gas on my old v6 camaro.
Old Nov 29, 2007 | 12:10 AM
97targa's Avatar
97targa
Default RE: nitrous
ORIGINAL: ZW99GT
YES gotta retard the timing for a ZEX kit and that kind of a shot. Also, you MUST get the bottle pressure up to 950 before you run it. It can and will take up to 20 minutes to get your bottle up to temp with a bottle heater.
I did run an NX wet kit with iceman solonoids at 100shot with no timing retard and one step colder plugs NGK TR6's gapped at .035" and had zero issueon a stock tune and 93 octane, however the two kits cannot be compared. NX is way better and more accurate in their solonoids and also I was only doing a 100shot. A 150 is a whole diff. ballgame! Good luck
Old Nov 29, 2007 | 12:17 AM
ZW99GT's Avatar
ZW99GT
Default RE: nitrous
ORIGINAL: 97targa
ORIGINAL: ZW99GT
Yea, heating the bottle SUCKS!
It's been real cold here, so I've been bringing the bottle inside and putting it into the bathtub, and get it up to about 1100PSI and let it sit there for awhile. It'll retain ~1000psi in the trunk for quite a while if it's not freezing ***** outside.
Old Nov 29, 2007 | 12:22 AM
meandmypony1
Default RE: nitrous
yea imspraying a 125 now with 2 stages colder plugs and 4 degrees of timing at about 960 to 990 psi
