suspension help
Old Dec 2, 2007 | 05:34 PM
greenyGt's Avatar
greenyGt
Default suspension help
I'm putting a 460 in a sn95 body 95 to be correct.
I already know i need a tubular K member for the swap,
Anyone know wheres a good place to get this?
Anyone also know a good site for tubular A arms?
I think i'm gonna be running fox4cyl springs cut a half coil,
whats a good strut to run?
and as for the rear? any suggestions, websites are appreachated(sp)
Old Dec 2, 2007 | 05:43 PM
wisk's Avatar
wisk
Default RE: suspension help
UPR sells a lot of suspension components that you might want to look into.
Maybe also Maximum Motorsports?
Old Dec 2, 2007 | 05:45 PM
97targa's Avatar
97targa
Let me get this correct, you want to put a Ford 460 which is a Big Block into your 95gt and use 4cyl springs that are cut??..LMAO You cannot even use them without being cut. If you use your stock GT springs, I bet you would get a 2"lowered appearance. The weight difference is HUGE! Like 200lbs. I think it's a terrible idea to put such a ridiculous motor like that in your car to begin with. You can get just as much power for the same price out of a 302 bored sb, just not as much torque.
Old Dec 2, 2007 | 05:57 PM
greenyGt's Avatar
greenyGt
ORIGINAL: 97targa
I want something different..
if you have nothing nice to say dont say it at all,
Old Dec 2, 2007 | 05:59 PM
greenyGt's Avatar
greenyGt
with some weight reduction , i'll be in the mid/low 11's
have fun with a 302 getting into the11'swith the same amount of money that the 460 will cost.
Old Dec 2, 2007 | 06:35 PM
wisk's Avatar
wisk
ORIGINAL: greenyGt
ORIGINAL: 97targa
He usually doesn't have anything nice to say, but still does.
Old Dec 2, 2007 | 06:39 PM
GhostRider02GT's Avatar
GhostRider02GT
ORIGINAL: wisk
ORIGINAL: greenyGt
ORIGINAL: 97targa
LMAO
Old Dec 2, 2007 | 07:59 PM
oxfordgt's Avatar
oxfordgt
With the amount of weight you are going to be dropping into the front end you will have to go to a coilover set up. If you plan on drag racing this thing coilovers up front is the way to go. I would highly suggest a tubed K member just to help with the weight factor. QA1 sells a kit (K member, a arms, adj struts, coilovers and springs) for around $1200 that is for the 94-95 gt and all you will have to buy is the motor mount conversion to drop in the 460.
For the rear get a nice set of drag springs, control arms and adj shocks.
Old Dec 2, 2007 | 08:14 PM
greenyGt's Avatar
greenyGt
ORIGINAL: oxfordgt
Thankyou
I will document this build, I have the car and i'm gonna begin to rip her down tomorrow or whenever i get room in my garage.
Old Dec 2, 2007 | 08:16 PM
oxfordgt's Avatar
oxfordgt
If you have any questions pm me. I already swapped a 460 nitrous fed motor into a 91 fox which isn't much different then what your doing.
