installing s/c
Old Dec 4, 2007 | 04:48 PM
1fast 99gt's Avatar
1fast 99gt
Default installing s/c
how hard will it be to install a vortech s/c anywone have a write-up on it?
Old Dec 4, 2007 | 05:04 PM
oxfordgt's Avatar
oxfordgt
Default RE: installing s/c
Its not hard at all, its just a bolt on. I have installed them in under 5 hours (including beer runs and wendys run). The hard part is the oil pan. Procharger for the win I can slap that puppy on in about 4 hours.
Old Dec 4, 2007 | 05:10 PM
1fast 99gt's Avatar
1fast 99gt
i know i dont want to tap the pain. i might have a shop do it that is going to tune my car.
Old Dec 4, 2007 | 06:47 PM
Quicktime_GT's Avatar
Quicktime_GT
They have some pretty good instructions on the internet.. its not that bad..
Its the unexpected things that gets ya
Old Dec 4, 2007 | 06:49 PM
Cornbread01's Avatar
Cornbread01
its not hard at all the tap is only never wrecking... just take you time and do as the manual says very easy.... to me the hardest part is getting the belt on and lined up but that is easy too.
Old Dec 4, 2007 | 07:23 PM
bjh061487's Avatar
bjh061487
if a supercharger is easy to install, then that means anything i ever buy i can install myself... haha... don't you need special tools to install a supercharger?
Old Dec 4, 2007 | 07:51 PM
1fast 99gt's Avatar
1fast 99gt
yeah i think i might take it to a shop to get the oil pan taped. anywone know how much this would be?
Old Dec 4, 2007 | 09:09 PM
oxfordgt's Avatar
oxfordgt
You don't need special tools to install a SC just a basic socket set.
You can tap oil pan its not that hard really its just awkward (spelling) and time consuming. The best way to do it is to take a punch and make the hole, then grease the crap out of the tap and fun it half way. Clean the hole and the tap and regrease the tap. Then run it all the way through. Clean the hole and tap again regrease and run it through again. Clean the hole then drain the oil. Take about 8 qts of the cheapest oil you can buy and dump it in. rock the car back and and drain the oil again. Then just hook up the lines fill with good oil and your all set.
Old Dec 4, 2007 | 11:39 PM
Cornbread01
if you can turn a wrench you can install a supercharger.... not that hard at all.
Old Dec 4, 2007 | 11:41 PM
2000GT4.6's Avatar
2000GT4.6
So far as the supercharger install iteself the vortech manual is a very good one, it pretty much details everything you need to do. you just need to GO SLOW and pay attention to the manual. I spent probably 30 minutes trying to figure out stuf funtil I realised I was in the 96-98 section of the manual.
So far as the tapping, it is NOT a big deal. Here is precisly what to do:
First you get the blower etc all hung and then lay the line down where you want it. It doens't have to be perfect because its not a metal line, it has rubber/flex hose on it so you can be off a bit. Mark the spot where you want it to be tapped.
Next, take a starter punch and start the hole. Then you will need a large tapered punch and a micrometer. The manual will tell you what size hole you need (if it doesn't the tap size will tell you, usually right on the tap). Measure the tapered punch with the micrometer and find the correct size. Use a marker (sharpie) and mark all the way around the tapered punch so you can see it from every angle.
The punch I got was too big, so I also had to saw off part of the fat end to get it lined up under the car. use a hammer and gently tap the punch in until you are up to the line you made. You now have the perfect size hole for your tap.
LIBERALLY grease (with heavy axle grease) the tap and tap the hole. If it starts to get hard to turn then remove the tap, clean it all off, and start over. Afterwards, change the engine oil. I acutally put about 2 extra quarts in the engine and then drained the entire thing to just make sure, but I never saw anything come out other than oil.
Its easy, and if you do it this way you have a nice deep threaded hole to work with.After I gotall the things I needed it didn;t take 10 minutes todo.
