Tuners/Programers info needed!
i have heard of sct diablo and others. i also heard of Hypertech. has anybody had any experience with them or heard of anything about em? if so Info needed here. thanks
I have a diablo tuner I am selling for 200 plus shipping. if you are interested just send me a pm...
It's a great tuner.. you can do many things with it including but not limited to installing the diablosport performance tune, turning off rear 02 sensors to allow you to run an o/r midpipe, turn off the traction control button, and alot of other stuff..
U7146 Specific Features:
Dual timing adjustment points (2000-4000 RPM / 4000-7000 RPM)
Timing table (+10% / -40%)
Dual fuel adjustment points (2000-4000 RPM / 4000-7000 RPM)
Fuel table (+40% / -15%)
Idle (+/- 20%)
On/Off Switch for Traction Control
Raise Speed Limiter
Rev Limiter
Re-Calibrate Speedometer for Gear and Tire Size Changes
WOT Shift Pressure
Part throttle shift firmness
RPM Shift Points
Torque Modulation (for better shift feel)
Cooling Fan ON/OFF Temperatures
Rear Oxygen sensor disable (use for off-road vehicles only)
Disable EGR (use for off-road vehicles only)
Internet Updateable
Idle (+/- 20%)
Raise Speed Limiter
Rev Limiter
WOT Shift Pressure
RPM Shift Points
Internet Updateable
YoungStangsMan
Sep 5, 2015 07:01 PM
panic
Aug 25, 2015 09:34 AM
dba Brakes
Aug 21, 2015 07:07 PM
