hardballer intake manifold
Old Dec 29, 2007 | 05:00 AM
adam_ferguson's Avatar
adam_ferguson
Default hardballer intake manifold
doesanyone have / know anyone who has tried that HPS hardballer on an N/A setup? if so how was the gain? how do you like it? install seems easy.
Old Dec 29, 2007 | 09:49 AM
Dsmfighter's Avatar
Dsmfighter
Default RE: hardballer intake manifold
Looks over priced. I'll buy a used one when I blow my intake up.
Old Dec 29, 2007 | 10:00 AM
silverstang1996's Avatar
silverstang1996
unless you have a lot of mods, or soon will get a lot it's not worth it. It has pretty minimal gains on GT's with just a few bolt ons or something
Old Dec 29, 2007 | 01:07 PM
adam_ferguson
what makes you guys say this? word or mouth or you actually have physically seen it.
Old Dec 29, 2007 | 02:33 PM
nathansee3's Avatar
nathansee3
To take full advantage to the intake you need pp heads and cams. . . .
Old Dec 29, 2007 | 02:57 PM
lizzyfan's Avatar
lizzyfan
Underboss
ORIGINAL: nathansee3
Even then you'll prolly loose some bottom end! Too much air for crappy 2v! S/C or turbo and gains will be seen!
Old Dec 29, 2007 | 03:23 PM
tbirdscwd's Avatar
tbirdscwd
I don't think there has been any substantial gains n/a using any aftermarket manifold without PP heads/cams. Plus, the hardballed looks identical to the stock one except for the material. Unless it misteriously flows some crazy amount of air, you will probably lose power on a n/a setup because of how much more heat the manifold will retain vs stock plastic.
Old Dec 29, 2007 | 03:38 PM
silverstang1996
ORIGINAL: adam_ferguson
when you spend like 7-800hundred bucks, go to a dyno and see you only picked up 10rwhp, you'll see what we were talking about
Old Dec 29, 2007 | 06:24 PM
adam_ferguson
ORIGINAL: tbirdscwd
the plenum area is substantially larger , and also the runners are a full 1 inch smaller. as for the low end power loss ,i would be happy to lose some , i have it to lose. you don't need low end"power" in a drag race except forthe launch.even if you lose some , you will gain it in your hole shot from spinning your tires less. (assuming you are racing on street tires like me).i look to physics and specs for my judgement. shorter runner = less velocity more volume = top end power low end torque. for a drag race you want top end power and low end torque. the manifold is a track manifold , its not for the seat of your pants feel. i don't know ,i'm happy to hear what you all have to say , but if you don't have this manifold , or know someone that has this manifold , you aren't being helpful, i just want to know if it helped improve times at all, and what kind of power it made , dyno proven preferably.
Old Dec 29, 2007 | 06:34 PM
Sxynerd's Avatar
Sxynerd
There crap for n/a unless your higher compression or fully P&P
