CEL PROBLEMS
Old Jan 3, 2008 | 10:09 AM
pboeschen's Avatar
pboeschen
Default CEL PROBLEMS
My 2002 GT with almost 60,000 miles on it(mods: Diablo chip and K&N air filter installed at about 30,000 miles) began to give me CEL codes on 12/3. The first three codes given were:
P1131 - Lack of HO2S11 switch - Sens Indicates Lean (Bank 1)
P1151 - Lack of HO2S-21 switch - Sens Indicates Lean (Bank 2)
P0174 - System Too Lean (Bank 2).
Only noticeable problem was RPM's decreased and engine seemed like it wanted to die when I was not moving. First attempts to correct problem included cleaning the MAF with MAF cleaner from Advance and replacing the IAC valve. I cleared the codes with my OBD-II tool.
The car ran fine for a few weeks until I noticed that the car seemed like it wanted to die again when car was not moving on 12/31. CEL came on again, with the codes now being:
P1131 (again),
P1150 - Lack of HO2S21 Switch - Fuel Trim at Limit (Bank 2)
P0171 - System Too Lean (Bank 1).
Last night, I disconnected wire from negative terminal on the battery and cleaned MAF again.This morning, I reconnected battery and started the car with the MAF connector disconnected. After driving less than 500 feet, I heard what sounded like a popping noise in my exhaust. This is the first time that this has ever occurred.
I plan to replace PCV valve today with Motorcraft PCV since they are cheap ($12) from dealer to see if that works.
Anybody have any ideas? Thank you.
Old Jan 3, 2008 | 10:13 AM
Derf00's Avatar
Derf00
Gentleman's Relish
Default RE: CEL PROBLEMS
ORIGINAL: pboeschen
P1131 (again),
Pull your 02 sensors out and take a look at them. Sounds like those are having issues. (Not plugged in all the way, dying, contaminated etc.)
Bank 1 is passenger side, Bank 2 is Drivers Side. Since it's giving you lean codes it would be the Front O2 sensors since those control the A/F ratio.
Old Jan 3, 2008 | 10:35 AM
pboeschen's Avatar
pboeschen
Thank you for the quick reply. I will check the O2 sensors tonight.
Old Jan 3, 2008 | 11:12 AM
cliffyk's Avatar
cliffyk
TECH SAVANT
+1 on the O2 sensors (here's how to test them once you've got 'em out) [/align][/align]The MAF has to be connected or the PCM will switch to "limp" mode and the engine will run, but like crap...[/align]
Old Feb 20, 2008 | 11:06 AM
pboeschen's Avatar
pboeschen
I just want to update everybody on my problem. The problem was caused by a crack in the plastic hose that is connected to the PCV valve. My car runs like a champ again. Problem solved!
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
