Shift knob MGW
I just put my new roush shift **** on my MGW shifter. The problem is there is about an inch left of threads after fulling screwing the **** down. I can pull the boot up to it, but it looks like stock. My question is, can I cut an inch of thread off the top of the shifter without any complications?
As much as I would like to trust that opinion, it doesn't look like you do.. haha. But if anyone else has an opinion on this that would be much appreciated. Thanks in advance.
Before you cut anything, take a very small amount of anti-seize and put it on the shifter threads. Screw the **** on again and pull it back off... Use a flashlight and look in the **** to see if it's too shallow or if the threads are getting caught and you can't fully screw down... unless it's completely obvious the **** threads are too shallow.
ORIGINAL: Dan04COBRA
When I put a hurst T handle on mine I had about 1" of threads showing so I turned down a piece of aluminum on the lathe that just covers the threads.
I'll get a picture posted up later.
you can cut it but if you do you make that short shifter that much shorter(it makes it a little harder to shift in/out of gear)
ORIGINAL: Lefty
well i worked in a machine shop for 8 years, i know you can cut a threaded rod and still screw stuff on. but if you hack it up with a rough blade it wont work.
