terminator front bumper
Old Jan 12, 2008 | 01:03 AM
00raging stang's Avatar
00raging stang
Default terminator front bumper
well as some of you may know i ordered a terminator front bumper which should finally be here on monday. i was wondering what all i would need for the install and the fogs to be complete. i know i need to order the bezels which i actually already have second i know i need the actual fog lamps the only thing i was reading on another web site is that they are supposivly held in by brackets? would the brackets come with the fog lights or would i have to order those seperately from somewhere and if i did anyone know where i could get them from. and the last thing is as far as fitment for the new bumper i beleave read that someone said that the grill posts have to be moved back a 1/4 inch for everything to fit right is this true or is it something else, and if anyone has anyother information that would be helpful id appreciate it
Old Jan 12, 2008 | 05:59 AM
LynnBob Mustang's Avatar
LynnBob Mustang
Default RE: terminator front bumper
I'd like to hear this as well. Also will the factory fog lights plug right into the '99 and newer plugs?
What is the grill post that needs to be moved back 1/4"? I havn't heard that one yet.
Lynn
Old Jan 12, 2008 | 07:33 AM
QatarStang's Avatar
QatarStang
I've heard the stock hood won't close right on the termie bumper.....could be wrong, though.
Old Jan 12, 2008 | 08:36 AM
jrherald420's Avatar
jrherald420
thats why u have to move the post back, unless you use a hood for a cobra then you dont move it.
Old Jan 12, 2008 | 08:38 AM
jrherald420
the posts are the ones that are on each side of the grill and between both headlights
Old Jan 12, 2008 | 09:27 AM
5speedstang's Avatar
5speedstang
i just did this actully.
you need the fog lights
fog light beseles
fog light mounts
03 cobra pig tails (wireing harness for the fog lights)
chin spoiler
bumper and thats it.
you do need to push the posts back and drill 2 new holes but i cant find the link that shows exactly what you need to do. it wsa very helpful. but good luck.
Old Jan 12, 2008 | 02:26 PM
LynnBob Mustang
ORIGINAL: jrherald420
Do you have to mod the core support or anything for the posts to sit right?
Is it just as simple as placing the posts to where they look correct and then drill the new holes? Or isn't it that simple?
Lynn
Old Jan 12, 2008 | 03:17 PM
blackGTcp's Avatar
blackGTcp
Would an aftermarket hood sit right on a termie bumper? Just wonderin if someone with a cobra changed hoods if it would have a problem
Old Jan 12, 2008 | 03:33 PM
5speedstang
all you do is there are two screws on on top of each post. push the post as far back as it will go. and drill a hole where the hole on the post is. and thats all.
Old Jan 12, 2008 | 03:47 PM
jrherald420
if you use a cobra hood it should work with out drilling new holes.
