vacuum leak??
Old Jan 14, 2008 | 08:40 PM
blee69mustang's Avatar
blee69mustang
Default vacuum leak??
my cars seems like its having a rough time idleing. i've changed the spark plugs, got new wires, new fuel filter. it idles, but it seems like its having a hard. it shows the characteristics of a vacuum leak too. im just wondering what are the commom vacuum leak area??? so i can check them all... thanks guys
Old Jan 14, 2008 | 08:57 PM
timeformiller44's Avatar
timeformiller44
Default RE: vacuum leak??
well clean the IAC first...usually gives a rough idle dirty......then take some carb clean...spray the engine while its running...like around vacuum areas..and intake manifold...ull know you have a vacuum leak when you hit an area that has one..the engine will act up alil bit..then look around in that area
Old Jan 14, 2008 | 09:09 PM
Uncle Humjaba's Avatar
Uncle Humjaba
+1 check the IAC. mine got clogged and the car wouldnt run without some throttle.
Old Jan 14, 2008 | 09:11 PM
blee69mustang
ok thanks guys. Brain fart, whats the IAC again?
Old Jan 14, 2008 | 09:13 PM
Uncle Humjaba
idle air control valve... lets air get to the engine when the butterfly valve in the throttle body is closed. no air = no idle.
Old Jan 14, 2008 | 09:14 PM
blee69mustang
ORIGINAL: Uncle Humjaba
o ya duh, thanks a lot
Old Jan 14, 2008 | 09:23 PM
96GT226410's Avatar
96GT226410
CSMG Moderator
If the IAC doesn't help, check your PCV valve.
Old Jan 14, 2008 | 09:54 PM
blee69mustang
alright thanks...
Old Jan 15, 2008 | 04:38 PM
timeformiller44
PCV valve wouldnt caust a bad idle... unless its unplugged...but youd know it would be a pretty loud vacuum noise if the PCV was unplugged and car was running
Old Jan 15, 2008 | 05:00 PM
96GT226410's Avatar
96GT226410
CSMG Moderator
ORIGINAL: timeformiller44
You're wrong. If the valve is stuck open or broke his idle would sit real high and take a while to go back down, and between that time it would jump all around.
