Quick writeup on dropping k-member???
Was wondering if anyone had a link or a quickwriteup on how to drop your k-member. Thinking of just droping my k-member to replace my clutch( 2000 GT). . . .Thanks.
he has long tubes so he has to to take one side off.... welll.... here it is...
to remove the k-member (doing this on jackstands to sit it on the ground under the car)
take off wheels. decompress springs and disconnect struts. basically just put a jack under the control arm and lift up some on it then take the 2 strut bolts out. then take the 4 back bolts on the k member out. there are also 4 front bolts on it as well. it will drop right out like that. i leave it connected to the steering lines and such, but i disconnect it from the steering shaft on the drive side. it should take about 2 hours to remove the k member and get the header off. you will need a short 13mm wrench for some of those header bolts.
Hey was wondering if I could get the tranny partially out and unbolt the bellhousing from the inside and back the trans out and then take the bell housing out. That way I dont have to pull the k-member or the header. . . ? Just a thought.
heres a LT install link, you remove the k member to install, so just scratch off the rest of what you dont need.
http://www.fnsweet.com/garage/ltinstall.shtml#13
here is somethin I wrote when taken my transmission out.. pm me if you need any help
here are some pics..
We took these bolts loose:
Reduced: 50% of original size [ 1010 x 758 ] - Click to view full image[/align]
and these bolts: you can barely see one.. (the two by the struts)
To clear these dam headers:
5 foot extension to take out top starter bolt:
but.. we got it out..
autoedit
Sep 27, 2015 06:37 PM
Sep 25, 2015 06:30 PM
