spring install
Old Jan 16, 2008 | 02:39 PM
massmustang02's Avatar
massmustang02
Default RE: spring install
1.5" or less and even then there's always a possibility of needing cc plates and an alignment.
Old Jan 16, 2008 | 02:43 PM
blownbayou's Avatar
blownbayou
ORIGINAL: massmustang02
How would you know if you needed CC plates??
Starting to sound like a little more hassle than I was thinking of dealing with.
Old Jan 16, 2008 | 02:55 PM
massmustang02
After installing the springs you'll definitely need the alignment. Usually when you drop a car you'll get some negative camber. If it's past a certain point that your stock cc's can't handle then you'll know you'll need aftermarket ones.
Old Jan 16, 2008 | 02:57 PM
massmustang02
It's really not as much of a hastle as it seems. I say still go for it because it is one of the best mods the new edges/sn95's can get because it gets rid of their 4x4 look.
Old Jan 16, 2008 | 04:10 PM
Blown 04 Roush's Avatar
Blown 04 Roush
I ♥ Acer
I thought I read somewhere that you needed a spring compressor or something to work on your springs. Did I misunderstand, or is there another part that you need this for?
mtgldr
Feb 3, 2024 09:00 PM
PullTab
Oct 30, 2015 08:46 AM
Luke9222
Sep 4, 2015 06:46 AM
