the biggest NOS spray on pump gas
ORIGINAL: sstang
I think it would be good for the OP to step up to a small injector like 24#'s since his stockers are 19#'s. His stockers could probably handle it, but this way it's one less thing to worry about when upping the jet. He could at least get some 21#'s off of a 01+ GT for extremely cheap, but that really wouldn't be much of a difference.
No you don't. I'm running 525rwhp with 24# injectors. lol
I'm running a 200 shot on 93 EASILY and SAFELY. But when I go to the track, and I know im gonna be spraying the **** out of it, I'll fill up with 110. I then get to add some timing, which the car really likes.
If you don't need injectors, then don't buy em. Don't forget you'd have to swap the MAF too.
ORIGINAL: 99GreenGT
I know i dont need injectors but the wet kit taps into my fuel rails will need to upgrade those? and do you guys know what compression i should run?
A 150 shot should be fine on stock rails
Could probably handle what? He's putting on a NX wet kit. The injectors won't be asked to do anything at all. If he can run N/A with 19's, then he can run a 500hp wet shot with 19's.
Also, what is the reason why a blown motor needs 42# injectors, but a nitrous motor can make the same power on stock injectors?
ORIGINAL: ZW99GT
ORIGINAL: sstang
Your gonna need to step up your injectors as well.
careful with statement. dont want to step on the toes of any forum genious's. remember my thread? my motor (built N/A with a 125 shot of n2o), cannot make more than 400hp because "35# injectors cant handle that kind of power"
from how i understand it, assuming that its a wet kit (where thejuice is fed through one jet and addition fuel shot through another) the extra amount of fuel needed is supplied separetly altogether from the fuel rails/injectors....
in a boosted setup, more gas is needed from the injectors because there is no secondary incoming fuel....
i could however have it all wrong.....
your right a blower gets the fuel from the injectors hints needing bigger ones but on a wet N20 system it injects fuel and n20 with its own injectors but on my set up fuel for my n20 comes from my fuel rails so i did not know if my fuel rails could handle it.
ORIGINAL: Injected97GT
oh and i say NOS cuz thats the brand system i own.
ORIGINAL: sstang
Are you referring to me? And by the way, it's spelled "genius"....
