Installing TB/Plenum today
I know its not that difficult.. but is there anything I should know about before the install? How long does it take? Im pretty mechanically inclined..Ive changed heads on an LT1. But thats a bit different :DThanks!!
RE: Installing TB/Plenum today
Just be careful removing the TPS screws. They are locktited in and you can bugger the screw heads pretty easily. Take your time and you'll be OK[8D]
Yeah its not bad,just take your time and your be fine.It takes hour or so to slap them on.
ORIGINAL: JayC Just be careful removing the TPS screws. They are locktited in and you can bugger the screw heads pretty easily. Take your time and you'll be OK[8D] |
Other than that, just remember where everything goes! I'm not mechanically inclined at all and the entire install took 45 minutes.
ORIGINAL: GTVert00 Other than that, just remember where everything goes! I'm not mechanically inclined at all and the entire install took 45 minutes. |
you will have to watch the throttle body when installing the end of the throttle cable you may need to get a piece of sand paper and sand down the piece at the end of the cable to fit into the throttle body fitting(it can be very snug) and it will be a lot easier to install. i had to do this with my BBK...........
It was a little snug with my car, but nothing a little muscle couldn't fix :D
everything is a simple swap just becareful with the tps screw like the others are mentioning
takes probably 45mins to an hour for ya |
haha yeah damn those tps screws!!!!! its an ez install shouldnt have n e probs tho
