suspension time
well im getting ready to do some suspension work, seeings i have stock suspension. im not sure on which springs to go with. has anyone had any experience with the eibach drag springs?? im gonna either go with the eibach drag springs or the H&R springs, im not sure on which one to go with. any suggestions?
If ya want an inexpensive, effective drag/street set up.....Fox body 4 cyl front springs, 99-04 stock GT rear springs with dead coil cut off, solid or adj lower CA's and double adj upper CA's, Moser or TA Performance rear end girdle. Then if ya want to go all out. UPR tubular K-member, tubular a-arms, UPR coil overs up front and rear suspension set up listed above. Then you can add the UPR Drag anti-roll bar set up on the rear.
musnicki
Sep 23, 2015 07:11 AM
