180 degree stat?????
Old Jan 23, 2008 | 09:25 AM
Kmelfi11's Avatar
Kmelfi11
Default 180 degree stat?????
I saw that people are talking about this i dont really know much about it and it seems to be a good next mod can anyone help me with where i can get it, and some info on it?
Old Jan 23, 2008 | 09:48 AM
blueboosted95's Avatar
blueboosted95
Default RE: 180 degree stat?????
You can usually find them at any parts store on some models however really doesnt help you much unless you have a blower or some serious mods. because your pcm from factory is set to run at certain temps. and actually it could make your car run worse IMO Fuel burns better when hot!
Old Jan 23, 2008 | 10:04 AM
35thAnni99GT's Avatar
35thAnni99GT
From: Where gunshots are more common than birds chirping
So if I have a blower how does this help me?
Old Jan 23, 2008 | 10:21 AM
blueboosted95
I think its recomended because of the amount of air and fuel is increased with supercharging and a slightly lower temp. will ensure that the fuel doesnt overheat due to increased combustion! Just a guess...
Old Jan 23, 2008 | 10:45 AM
35thAnni99GT
So that I can run more timing or what? I have cats still on my car I'm not trying to ruin them running unburnt boo boo through them
Old Jan 23, 2008 | 12:10 PM
ponysnake99's Avatar
ponysnake99
the most a lower thermostat will do is provide a little more insurance when it comes to overheating, there is no hp gain or direct benefit from havig one for a street car. the only computer function affected would be your engine temp guage, which will look like it runs colder than normal. going so low as 160* stat will affect performance because the engine will continue to run at its warm-up stage which implements more fuel, you'll run a little rich which can affect other systems. in reality, running cooler (more dense) air and fuel will help performance on minute scales, after all, heat is inefficency and loss of power.
seths96gt - hotter fuel only increases mpg, not power
35thanni99gt - i wouldnt run more timing, while the temp the stat opens will be lower, the actual combustion temp will not vary great enough to advance timing. however if u want to persue it, talk to a local shop about bumping up a degree or two
Old Jan 23, 2008 | 01:47 PM
fruhdaddy's Avatar
fruhdaddy
if you want one summit has them for $12
mtgldr
Feb 3, 2024 09:00 PM
BOB ROME
Jul 26, 2023 01:54 PM
Gene K
Oct 21, 2015 11:37 PM
Explosive
Oct 2, 2015 07:45 AM
UrS4
Sep 30, 2015 10:13 AM
