Long Tubes
im thinking of getting long tubes and a shorty o/r h
how hard are they to install if i would do them by my self or how much would i cost on avearage to have them installed
are stainless steel worth the extra or are the ceramic coated just as good
im thinking bbk headers and midpipe
if you can affored it buy stainless steal. on the header install; if you have access to a lift, i think its not to bad, but if you plan on doing it in your garage on jack stands, its a bitch.
o-yeah be prepared to drop the k member. I have never done the install, this is just some things i have read.
ORIGINAL: josh.davis
I would definatley take it to get it installed unless you have a lift and something to hold the engine up after dropping the k member. Im getting my longtubes installed right now. But if u do have the money then go stainless if not ceramic coats just as good. But it will run you around average 450-500. Do you have an automatic?
i just figure if i can get away with ceramic i can use the extra money on other stuff
i do not have acces to a lift but my uncle a this pit in his barn that we pull cars over to work on them which i think may work just as well as a lift
when i did them on my GT we didnt drop the kmember, we did jack the motor off its mount a little, and that job was a complete bitch. we even had a full lift with the car 6 ft in the air at some points. the 4.6 header job is not fun
so the 450-500 is just on install right
yes i have an auto
does the tranny make a difference on what long tubes will fit or are they all made to work with both
yes i have an auto
ORIGINAL: 99 GT vert
yes i have an auto
yes i have an auto
