Those with 4 10's
I'm still confused about a couple of things with gears....if 3.73 and 4.10 gears are so much better, why didn't Ford just put them in as standard? By looking around on-line, it doesan't appear that higher ratio gears cost more than the stock gears already in the Mustang, so I don't think it was cost. If not cost, what's the major draw back that would make Ford not want them in as standard?
ORIGINAL: Be Rad 13
4.10 s in a 5 speed area great i wouldnt have gone any other route... pple gave me **** when i told them i was going 4.10's with f/i they said it would be to much... i still think there could be more... you do loose some tracktion but with good tires and some u/l controll arms youll get that back. so i say go for the 4.10's
GTnate, you better have some more mods done before you post with "LS What?" in your sig.
I have 4.10s with my 5 speed....wouldn't have it any other way (unless I get 'charged and move to Germany and drive the autobahn everday).
ORIGINAL: 01snake
i have 3.73's now and they blow
your goin the wrong way[8D]4.30's or 4.56's man
ORIGINAL: Ecstasy
i have a 97 cobra, when i bought my car it had 4.10s, i dont like em, and im probally going to install 3.73s. so i guess im the first person you've met that would rather 3.73's over 4.10s.
GOTTA CALL IT...
Thumbnail Image
Thumbnail Image
But anyways i am definetally going with the 4.10s. If i dont like them, witch i doubt i wont, ill go lower.
I have the stock 3.55s in mine and I probably won't go lower than 4.30's. It will make 5th work in the city. I think a lot of people are worried about highway driving, but the rpms aren't that much different.
Here is a gear calculator: Clicky
Mach1 4R70W ratios as follows
2.84
1.55
1.00
0.70 (OD)
Manual
.62 ratio, 80mph, at X.XX:1 rear gear ratio
3.55 = 2304 rpm
3.73 = 2421 rpm
4.10 = 2661 rpm
4.30 = 2791 rpm
4.56 = 2960 rpm
top speed w/ 3.55s, 5th gear @ 6798 rpm = 236 mph
top speed w/ 3.73s, 5th gear @ 6780 rpm = 224 mph
top speed w/ 4.10s, 5th gear @ 6787 rpm = 204 mph
top speed w/ 4.30s, 5th gear @ 6769 rpm = 194 mph
top speed w/ 4.56s, 5th gear @ 6771 rpm = 183 mph
Auto
.70 ratio, 80mph, at X.XX:1 rear gear ratio
3.55 = 2602 rpm
3.73 = 2733 rpm
4.10 = 3005 rpm
4.30 = 3151 rpm
4.56 = 3342 rpm
top speed w/ 3.55, @ 5789 rpm = 178 mph
top speed w/ 3.73, @ 5775 rpm = 169 mph
top speed w/ 4.10, @ 5784 rpm = 154 mph
top speed w/ 4.30, @ 5791 rpm = 147 mph
top speed w/ 4.56, @ 5765 rpm = 138 mph
2.84
1.55
1.00
0.70 (OD)
Manual
3.55 = 2304 rpm
3.73 = 2421 rpm
4.10 = 2661 rpm
4.30 = 2791 rpm
4.56 = 2960 rpm
Auto
3.55 = 2602 rpm
3.73 = 2733 rpm
4.10 = 3005 rpm
4.30 = 3151 rpm
4.56 = 3342 rpm
