Installing HID's
when i installed my HID's, i had my front bumper off bc i was swapping out bumpers with my GT, so i installed them on the main frame behind the bumper.. but otherwise, put one right on the wheel well right next to the cold air intake and screw that down.. and put the other one wedged in between the battery and the frame..
i know there is atutorial with pictures but idk where it is..
I mounted the headlight ballasts in the engine compartment. One behind the battery and between the fender, the other under the CAI I have. I used some strong double sided tape (3M I think) to secure them.
The fog light ballasts I mounted where wisk did. There are some screws that stick out that work perfectly for it. The bolts that came with the HID kit fit on them as well, so it was perfect.
I mounted my right box on the electrical panel next to the CAI with 3M tape and zipties, I mounted the right box on the fuse panel behind the battery
USE RELAYS FOR YOUR WIRING
Sep 10, 2015 08:39 PM
