IAC Problem?
Old Feb 28, 2008 | 09:08 PM
KJohnson99gt's Avatar
KJohnson99gt
Default IAC Problem?
usually on cold starts my car seems to wanna cut out or stall when i hit a small bump in the road(very small) it only does this after about 10 min of running after that its fine..should i clean the IAC or replace it or is this something else
Old Feb 28, 2008 | 09:23 PM
baino's Avatar
baino
Default RE: IAC Problem?
it might just be that your o2s havent warmed up andare sendin bogus readings to your computer. In other words, maybeyour carsnot warmed up. not sure about 2v but my 4v hates trying to move when its not warmed up.
Old Feb 28, 2008 | 09:47 PM
KJohnson99gt
yea i thought about that too but why would it do it only when i hit small bumps?
Old Feb 29, 2008 | 08:29 AM
baino's Avatar
baino
cause foot to bounce justa bit on accelerator (doesnt take much)and car starts to jerk. would help with a little more car info, ex- (manual, auto, year, DOHC, SOHC, upgrades).
Old Feb 29, 2008 | 08:39 AM
99BlackPonyGT's Avatar
99BlackPonyGT
aka 'Negative Nancy'
i highly doubt its the IAC but it wouldnt hurt to clean it anyways...pull it off and clean it out with some carb cleaner....takes 5minutes... my car would run fine when i fired it up, but if i drove somewhere and then shut my car off and waited like 5-20 minutes and start it, it wouldnt idle...and sometimes getting off the freeway puttng it into neutral and coming down the ramp it would stall out....cleaned the IAC and its fixed now...that doesnt sound like your problem though
Old Feb 29, 2008 | 10:01 PM
KJohnson99gt
99 gt auto gears k&n chip and tune
Old Mar 1, 2008 | 08:34 AM
baino's Avatar
baino
its an auto so that kinda throws my theory out. dont know, try 99's cleaning idea maybe. If not then the only other thing i can think of is that it is in the wiring, bumps cause wires to spark or disconnect temporarily. sorry, good luck
Old Mar 1, 2008 | 09:24 AM
KJohnson99gt
thanks guys
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
Scottyboy187
SVT Forums
Sep 13, 2015 10:23 PM
