Cams???
Old Mar 4, 2008 | 08:35 PM
hpwrestler220's Avatar
hpwrestler220
Default Cams???
i know absolutely nothing about cams and heads. i just know that when you get stage 1,2,3 or custom grind, etc, your powerband is greatly improved.. idk how to explain it since im a noob with this but for instance:
a stock GT stops making power at like 5k rpm???
if you put stage 2 H/C in your car, would your internals or valves or w/e be able to handle the extra RPM difference on a stock bottom end?? bc power will probably be cut off at like 6500k or something?? so would your engine be able to safely handle the extra 1500rpm's that its making power through??
i hope you guys understand what im asking bc im clueless as to how to explain it differently
Old Mar 4, 2008 | 08:38 PM
CAMDUP's Avatar
CAMDUP
Default RE: Cams???
https://mustangforums.com/m_3727594/tm.htm
Old Mar 4, 2008 | 09:08 PM
hpwrestler220
Default RE: Cams???
im an idiot.. i clicked that thread once before and i was just like "ehh too much to read". but i just read it and it answers my questions.. thanks.
you guys think stage 1 cams are worth it??
Old Mar 4, 2008 | 09:16 PM
blackGTcp's Avatar
blackGTcp
Default RE: Cams???
Im questioning the same idea. I really dont want extremely large gains. I just want an extra 20-30. Just for a little exta pep without having to buy all kinds of other pieces to make it work right
Old Mar 4, 2008 | 09:17 PM
NeedStangSpeed's Avatar
NeedStangSpeed
Default RE: Cams???
I don't, that's why I've been pounding the stage II thread on here to make sure it was ok to do it. Same amount of work plus springs, may as well go with stage II, but this is just my way of looking at it.
Old Mar 4, 2008 | 09:30 PM
avlon06's Avatar
avlon06
Default RE: Cams???
stage II's i have read are the better way to go. and if your just looking for 20-30 hp kinda expensive way to do it
Old Mar 4, 2008 | 09:44 PM
NeedStangSpeed
Default RE: Cams???
stage I's won't come close to 20-30 hp extar, stage II's barely will. I think stage II's are rated maybe at 15hp, depending on your mods that might help a little.
Old Mar 4, 2008 | 09:54 PM
01snake's Avatar
01snake
Default RE: Cams???
stage 3's
end thread/
Old Mar 4, 2008 | 09:57 PM
timeformiller44's Avatar
timeformiller44
Default RE: Cams???
comp stage 2's with patriot stage 2 heads...ok for bottom end?
Old Mar 4, 2008 | 10:01 PM
NeedStangSpeed
Default RE: Cams???
ORIGINAL: 01snake
stage 3's
end thread/
Wouldn't this require a forged bottom end to get full effect of these cams by running at higher rpm's?
