how reliable will this be??
Old Mar 9, 2008 | 06:48 PM
00raging stang's Avatar
00raging stang
Default how reliable will this be??
well as many of you that have read my previous posts lately know that when i went to put my gears in down at a local shop last thursday i found out that i needed to replace my axles because they were pitted. Now before i had discovered this i was alittle concerned about them anyway because i want tobe able to run like a mickey thompson tire without breaking my axles( i would think the axles would go before the carrier). so tommorow my axles will be here, i ordered Alloy performance axles from summit, and was wondering if they would be able to handle the type of tire im looking to use.
Old Mar 9, 2008 | 07:01 PM
JayC's Avatar
JayC
Default RE: how reliable will this be??
I would get a second opinion on your axles. If axles are needed I would get Moser 31 splines. Summit will return those for you, no problem.
Old Mar 9, 2008 | 07:05 PM
00raging stang
i have to work with what i have, for one i do not have nearly eough money to get a new carrier for the 31 splines or i would have went with them, and for the second reason my car is up on the lift so it has to get fixed asap.
Old Mar 9, 2008 | 07:12 PM
JayC's Avatar
JayC
Well in that case you'll probably be OK[8D]
hpwrestler220's Avatar
hpwrestler220
i also agree that u should get a 2nd opinion
edit: spelling
Old Mar 9, 2008 | 11:14 PM
00raging stang
anybody else?
Old Mar 9, 2008 | 11:18 PM
oxfordgt's Avatar
oxfordgt
I wouldnt run MT tires with those axles. They arnt much stronger then stock. I would send them back and use your stock ones till you have the money for 31 spline setup
Old Mar 9, 2008 | 11:27 PM
00raging stang
they are suppose to be like 34% stronger or some sh*t
Old Mar 9, 2008 | 11:32 PM
oxfordgt's Avatar
oxfordgt
I wouldn't trust them. Dont put nice wheels on with the MTs. Get a set of crap wheels for them. When the c clips let go they will destroy the wheel when the axle flys out.
Old Mar 10, 2008 | 02:17 AM
friendofkeebler's Avatar
friendofkeebler
Or you could just pray before every drag!! lol
