problem HELP!
Old Mar 14, 2008 | 12:22 AM
00raging stang's Avatar
00raging stang
Default problem HELP!
ok so i recieved my new Alloy axles and the shop putting them in couldnt get me ABS tone rings off of my stock axles and none of the axle companies sells them, long story short i cant find these things anywhere, im being told that you are suppose to pry them off of the stock axles and press them onto the new ones, but the tone rings are aluminum and the axles are steal. once the shop heated them up and tried to pry them off they just started to bend. so basically enless one of you guys know where i would be able to find them i have 2 choices. i can either put it back together with the better axles but then i will have no ABS or i can get the original stock axles from ford which arent as strong but i will have ABS, what would you guys do.
sorry for the long post, but i seriously need some help here
Old Mar 14, 2008 | 05:59 PM
00raging stang
Default RE: problem HELP!
anyone?
Old Mar 16, 2008 | 01:26 AM
00raging stang
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
