HELP!!
Old Mar 22, 2008 | 11:58 AM
cooldbz12's Avatar
cooldbz12
Default HELP!!
Ok im fed up with this problem on my 2003 mach 1, My CEL popped up agian! yesterday for running lean on both banks, everytime i change something it goes away for weeks to months and then just pops back up! Sometimes i get lean on one bank then sometimes on both banks. here is what ive done.
Fuel filter changed
spark plugs changed
MAF Cleaned
Checked For Vacume Leaks - None that i could see
Replaced the 02 Sensors in the front - Back 02s are off
Ran Injector Cleaner Seafome
No Exhaust leaks
Checked Fuel Pressure - 28-31psi on ide goes up to 40psi when i tap the gas.
The only symptoms i have of something wrong is My car shakes very slightly during idle just enough only i can notice it, and my tail pipes are black from the inside.
So what else could it be???????????????????????????????????????????:conf used:
Should i just replace my fuel injectors, fuel pump, MAF sensor?[/align]__________________[/align]
