Are these cams too big?
Old Mar 28, 2008 | 11:04 PM
perfect.disguise's Avatar
perfect.disguise
Default Are these cams too big?
On a full bolt-on PI 2v?
They have an rpm range of aproximately 2000-6500 and have a noticably lopey idle, but not overly radical for the street. They will work on naturally aspirated or with a blower. The cams were custom made on new blanks by Schneider Racing Cams in San Diego, CA.These were made on gun drilled blanks so they are very light (i.e.,hollow center).
Valve lift is 0.468" and duration is 284 degrees. Camlift 0.260" and durationat 0.050" lift is 220 degrees. Lobe separtion 114.
Wrong ones to go with?
Old Mar 28, 2008 | 11:10 PM
BostonBruins 2003GT's Avatar
BostonBruins 2003GT
Default RE: Are these cams too big?
i dont buy the "works well with a blower or N/A" part of it. And the RPM powerband looks kinda low. Most cams for our cars that really make power make it a lil higher in the rev range.
sounds like a stage I type cam grind
Old Mar 28, 2008 | 11:23 PM
timeformiller44's Avatar
timeformiller44
113 LSA
CAM SPECS: INTAKE EXHAUST
Adv duration @.050 270 274
Duration @.050 234 238
Valve Lift .550 .550
my cam
Old Mar 29, 2008 | 11:05 AM
perfect.disguise
Considering the RPM range and whatnot wouldn't this be like a stage 2 cam.. or similar?
GimpyHSHS
19
Dec 19, 2023 01:12 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
UrS4
Sep 30, 2015 10:13 AM
junior04
Sep 28, 2015 10:53 AM
