timing chain
Old Apr 5, 2008 | 11:32 PM
jartale's Avatar
jartale
Default timing chain
I have a 2001 mustang gt. I need to change the timing chain.
The Haynes repair manual say to take the oil pan off in order to take the timing chain cover off. Do I actually need to do that?
Can I get around it? It seems to be a lot of work considering that Haynes says that I need to take the trasmission out to take the oil pan off.
Joe Art
Old Apr 6, 2008 | 12:35 AM
96GT226410's Avatar
96GT226410
CSMG Moderator
Default RE: timing chain
You don't have to take the oil pan off. There are 4 bolts that bolt the timing cover to the oil pan. All you have to do is take those bolts off.
Old Apr 6, 2008 | 07:38 AM
Wishbone's Avatar
Wishbone
The timing chain is supposed to be self lubricating and self adjusting, why are you changing it? If you must then I would suggest doing the water pump at the same time.
Old Apr 6, 2008 | 10:11 AM
96GT226410's Avatar
96GT226410
CSMG Moderator
There's no real reason to change the water pump, you don't have to take it off to do a timing chain. And the chain isn't self adjusting, it uses oil fed chain adjusters. If you're going to replace the timing chain I would definetly replace those. And check the condition of your arms and guides.... By the way, why are you replacing the timing chain?
Old Apr 8, 2008 | 11:59 PM
jartale's Avatar
jartale
I am replacing the timing chain because it makes noise. Well there is a noise inside the timing chain cover I hope is the timing chain.
I thought my water pump was going bad but after changing with a new one I found out it wasn't the water pump.
mungodrums
Oct 7, 2015 04:01 AM
Golfsito
Oct 6, 2015 11:02 AM
clowe1965
Carolina Regional Chapter
34
Sep 28, 2015 09:18 PM
Sep 8, 2015 11:50 AM
