How much hp from cams?
Old Apr 6, 2008 | 11:40 AM
steve0914's Avatar
steve0914
Default How much hp from cams?
if i have a full bolt on car ( which i will with my t/b and plenum thats on the way) and i buy a set of cams, how much hp will i gain from the cams? also what else is needed with cams? tune? timing adjustment?
Old Apr 6, 2008 | 11:50 AM
jrherald420's Avatar
jrherald420
Default RE: How much hp from cams?
youll need new valve springs andtune or tuner
Old Apr 6, 2008 | 01:46 PM
96GT226410's Avatar
96GT226410
CSMG Moderator
Depends on the cams.
Old Apr 6, 2008 | 01:50 PM
Mustang_NTriangle's Avatar
Mustang_NTriangle
20-25 rwhp but will require a dyno tune and would figure you should be around 290-300 at the wheels if you have full bolts including Long Tubes.
Old Apr 6, 2008 | 01:55 PM
H0SS302's Avatar
H0SS302
ORIGINAL: 96GT226410
+1
with stage 1 cams you dont need new springs, but u will need a tune. stage ones net from 10-15whp from what i have seen. with stage 2s you need springs and a tune.
Old Apr 7, 2008 | 01:16 PM
10inch Terror's Avatar
10inch Terror
My Stage 1's see on average ~25 rwhp increases and can be used with stock springs. Will need a tune. My Stage 2's see about 10+rwhp more peak-to-peak. At higher RPMS, the gains will be greater. They gained 55rwhp @ 6000rpm on a stock 02GT over stock PI cams....
Old Apr 7, 2008 | 01:26 PM
1sloblckgt's Avatar
1sloblckgt
Send me some for free...
GimpyHSHS
19
Dec 19, 2023 01:12 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
