i was wondering about the o/d button
i think OD OFF makes your RPM's go up bc it eliminates the 4th gear?? idk something like that... notice how when you put it in O/D when ur in like 3rd gear, the RPM's shoot up about 1000?? you're getting into ur powerband quicker. so yes race with O/D off and traction off
ORIGINAL: RipTide7
All it does is stop you from going into 4th gear aka O/D
Some of these replies have me crackin up over here. O/D off is just that, off. It keeps the trans from shifting into overdrive..and is designed to be used when under heavy throttle at higher speeds, because overdrive isnt made for wide open throttle runs. IT doesnt increase hp or raise RPM limiters [&:]
ORIGINAL: WhiteFoxGT
+1
ORIGINAL: RipTide7
i dont think there was anything misleading in my post if you were referring to me..
ORIGINAL: moosestanggt
so at lower speeds is it better to race with the "o/d off" light on or just leave it normal??
ORIGINAL: 2k1gt
It doesn't matter. When you floor it your car will downshift to 2nd gear (or first depending on speed). Wether it is in 3rd or OD when you floor it wont make a bit of difference.
