Im having speaker problems
Old Apr 29, 2008 | 06:46 AM
ringored35's Avatar
ringored35
Default Im having speaker problems
I have a 97 GT Convertible. I still have the factory stereo with Mach sound. I hear a humming noise in speakers and a loud thunderous sound coming from the door speakers. It comes and goes. When engine is off I dont hear the humming noise but the thunder noise will come and go. Any Ideas ?
Old Apr 29, 2008 | 08:26 AM
Sxynerd's Avatar
Sxynerd
Default RE: Im having speaker problems
Turn down the radio all the way and rev your engine. If you get the same sound then you are in need of another grounding wire. You may want to check the noise reducers from your coil packs. If every thing is good then you more than likely have an ignition coil that the insulation has gone bad. Also check to see if your grounding wires have not gone bad (rusty or dirty) near the MACH amps/.
Old Apr 29, 2008 | 08:59 AM
1sloblckgt's Avatar
1sloblckgt
[sm=hail.gif]
Old Apr 30, 2008 | 07:36 AM
ringored35's Avatar
ringored35
thanks for the info, Would that also account for the loud, thunderous, door speaker noise as well ? It comes and goes.
Old Apr 30, 2008 | 08:27 AM
steve0914's Avatar
steve0914
[sm=hail.gif] +1
Old May 1, 2008 | 06:08 AM
ringored35's Avatar
ringored35
OK did what you said. I turned down radio all the way. Still hear the engine noise. Did you mean I need a new Battery Ground wire or Radio ground wire. WHere is the ground wire located for the mach amp ?
JoshyGT
Sep 19, 2017 08:52 PM
stangin1996gt
Sep 21, 2015 11:01 AM
unit91
Sep 15, 2015 09:53 AM
Doogie65
Sep 6, 2015 02:55 PM
TimeLord101
Sep 4, 2015 09:27 AM
