upper control arms
Old May 7, 2008 | 01:07 PM
99 GT vert's Avatar
99 GT vert
Default upper control arms
http://www.jegs.com/i/Granatelli/467/GMCA7900U/10002/-1
are these any good
Old May 7, 2008 | 01:19 PM
w8less's Avatar
w8less
Default RE: upper control arms
there are better out there.
if you dont have any suspension upgrade the lowers first
Old May 7, 2008 | 01:35 PM
SilvrStang's Avatar
SilvrStang
Id honestly go with steeda or UPR
Old May 7, 2008 | 01:43 PM
99 GT vert's Avatar
99 GT vert
so the front lca's would help me more than the rears
Old May 7, 2008 | 01:45 PM
99 GT vert's Avatar
99 GT vert
what im dealling with is i have a jegs gift card and i am not sure what to spend it on so i want to find something on jegs
Old May 7, 2008 | 01:47 PM
35thAnni99GT's Avatar
35thAnni99GT
From: Where gunshots are more common than birds chirping
ORIGINAL: 99 GT vert
huh?
Unless you have a 4wd mustang you wont have front LCAs. LCAs help more than UCA's for traction purposes.
Old May 7, 2008 | 01:55 PM
99 GT vert's Avatar
99 GT vert
ORIGINAL: 35thAnni99GT
huh?
wow i totaly miss read jaspers post
Old May 7, 2008 | 02:05 PM
avlon06's Avatar
avlon06
are upper control arms needed? i know LCA help with launches and what not, what do the UCAs help with?
Old May 8, 2008 | 01:37 AM
w8less's Avatar
w8less
ORIGINAL: avlon06
they help with the suspension alignment and you can adjust your driveshaft angle with adjustable uppers
Old May 8, 2008 | 01:40 AM
w8less's Avatar
w8less
since your options are limited check out lakewood. i had some of there traction bars on my 95 and noticed a big difference in spinning when i put them on.
if you can afford get the lowers and shocks. with some good tires you will notice a difference traction.
