New to mustangs
Old May 16, 2008 | 03:26 AM
96GT226410's Avatar
96GT226410
CSMG Moderator
Default RE: New to mustangs
Just keep looking around, I found a package deal. Someone bought all of the stuff and got rid of his car before he got a chance to put it on. I was waiting for 6 months until I found the deal I wanted.
Old May 16, 2008 | 03:37 AM
H0SS302's Avatar
H0SS302
ORIGINAL: brian1570
ORIGINAL: 96GT226410
^Save up for it. I did my PI swap for $700 and I got a lot of extra stuff to go with it (full PI swap kit, every gasket from the oil pan to valve covers, Melling oil pump, timing chain tensioners, water pump, etc).
where did u find all of that for so cheap? im looking at rebuilding the top end of my motor and its going upwards of 1500...
deals are all over the place. theres 2 ppl on my local forum selling pi heads with cams for 300. pi intakes are a dime a dozen and cheap
Old May 16, 2008 | 03:51 AM
Mustang9668's Avatar
Mustang9668
I had a 96 GT auto and I wish I wouldn't have spent so much time on pissy little mods that made little to no difference.
If I had it to do over again this is what I would have done without wasting money on other crap mods:
4.10's
PI swap--at least do the intake and cams since that is where most of the power comes from but if you do the heads to go ahead and do stage 2 cams while you're in there
3800 stall converter from BC Automotive
Dyno tune
For a tuner-get a dyno tune and just use whichever the tuner uses. It will probably either be the Diablo or SCT.
And yes PI swaps are all over the place. I've seen complete PI swaps on the classifieds for $500. Heads usually are around $300 with cams and intakes are usually around $125.
Old May 16, 2008 | 06:30 AM
dh04 red gt's Avatar
dh04 red gt
definetly change heads and intake combo. Its my understanding that in 1997 the ports are very small compared to 1999 and up. car and driver had segment on this and showed the diffrence on the heads and the newer heads were twice the size. probably why 1997 only had around 220hp and 1999to 2004had 260hp. but if you going to do a head swap don't go with stock check out patiot heads. or any aftermarket heads and intake combo. But its all up to you and what you want out of it.
Old May 16, 2008 | 07:02 AM
wolverine8490's Avatar
wolverine8490
I paid 85 for my PI intake, 90 for my PI cams, 25 for my PI valve springs and new retainers, 85 for all of the gaskets required,new heater hoseand valve seals, 52.90 for the coolant tube and water pump nipple, and40 on oil and anti freeze. You just have to look around. People pay to much for a lot of this stuff. The valve spring install was a pita btw. I ended up pulling the motor.
Total - 377.90
Well worth every penny. Next....... 5 speed swap and the Sniper SF tuner
Old May 16, 2008 | 07:51 AM
Sxynerd's Avatar
Sxynerd
I wish I would have done the entire 31 spine and gears. I'm regretting not doing them now. If I had to do them over again I would have done them first.
Old May 16, 2008 | 12:37 PM
brian1570's Avatar
brian1570
Blart
ORIGINAL: dh04 red gt
yes because aftermarket heads and cams r cheap......i think i will just kidnap the first lil kid i see and hold him for ransom, or maybe i will rob a bank. hmmm or should i sell my soul?
Old May 16, 2008 | 01:08 PM
H0SS302's Avatar
H0SS302
ORIGINAL: brian1570
definetly change heads and intake combo. Its my understanding that in 1997 the ports are very small compared to 1999 and up. car and driver had segment on this and showed the diffrence on the heads and the newer heads were twice the size. probably why 1997 only had around 220hp and 1999 to 2004 had 260hp. but if you going to do a head swap don't go with stock check out patiot heads. or any aftermarket heads and intake combo. But its all up to you and what you want out of it.
what is with you calling out everyone who suggests a mod over 100 bucs? get with the program dude cars aint cheap.
Old May 16, 2008 | 04:30 PM
bpark8824's Avatar
bpark8824
How hard is it to do the heads on ohc motor. The heads on an in block cam motor are cake but i dunno about all the timing and stuff with the mustang...
Old May 16, 2008 | 08:08 PM
Mustang9668
I would be careful with patriot heads. They have had issues in the past with there heads. Do some research before you decide.
