My GT is tugging
Old May 16, 2008 | 05:59 PM
nemo's Avatar
nemo
Default My GT is tugging
Hey guys whats up. My 02 GT has been tugging on me for a lil while, it happens when i either hold the gas pedal steady and sometimes when i give it some gas. I changed my ignition coils, and plugs, changed fuel filter and fuel pump. I know that i need to get my car re-tuned due to the fact i replaced my fuel pump and headers. Plus before i changed my fuel filter and pump my fuel pressure was at 29psi which is low, but now it reads 50 psi which is a big difference. This problem is driving me crazy can anyone give me some advice!!!!!
Old May 16, 2008 | 06:35 PM
99BlackPonyGT's Avatar
99BlackPonyGT
aka 'Negative Nancy'
Default RE: My GT is tugging
sounds like a miss... but it seems like you got everything covered....is it tugging like a misfire or is it maybe your clutch slipping?
Old May 18, 2008 | 10:45 AM
nemo's Avatar
nemo
its tugging like miss, I have changed my spark plugs with Bosch platnum 2 plugs and a guy at a car show told me that for some odd reason our 4.6 does not like those so im going to take them out today and look at them. But i really dont think that thats the problem.
Old May 18, 2008 | 04:50 PM
jmsjags's Avatar
jmsjags
it might be a bad oxygen sensor. one of mine is bad right now and it's causing a miss while cruising.
Old May 18, 2008 | 08:33 PM
nemo's Avatar
nemo
I fixed it thank god!!!!!!!!!!!!!!!!!!!!!! It was a loose spark plug. I couldnt believe it, I removed the ignition coil and then right when i put the socket on the sparkplug it was in there but loose, i could turn with just my hand on the etension. Boy did I get lucky, after I hooked everything up I started the car up and it was so smooth. [sm=bounceybounce.gif]
Old May 18, 2008 | 08:37 PM
99BlackPonyGT
use a torque wrench next time!!
Old May 18, 2008 | 09:42 PM
AZsGr8est's Avatar
AZsGr8est
nice.. Im happt for you... But idk why but my car oesnt like anything from Bosch either.
Wynn
Mar 14, 2010 06:00 PM
ben790450
Mar 17, 2008 11:42 PM
tommy2273boy
Mustang Videos
Jan 20, 2007 11:37 AM
