Cam Install = Bad Noise Help
Old May 22, 2008 | 04:04 PM
FastGT's Avatar
FastGT
Default Cam Install = Bad Noise Help
He guys, I recently finished installing my heads which I sent for a porting job and a set of COMP CAMS XE270AH (AKA 270s) Well when we started the car up it had this loud noise. It sounded like the lifters. We had charged them up and everything. So we took off the valve cover and everything was ok. We started it with the cover open and all the components ran ok. Heres a video, any suggestions. Sorry for the message that appears. had to resize the video because it was in HD, too big for photobucket.
http://s247.photobucket.com/albums/g...V_0112_NEW.flv
Old May 22, 2008 | 04:25 PM
lilmarc1988's Avatar
lilmarc1988
Default RE: Cam Install = Bad Noise Help
u didnt get answers from modded mustangs.com did u? u had a lot of replies though
Old May 22, 2008 | 04:27 PM
FastGT's Avatar
FastGT
I got some pretty good answers but just looking for second opinions
Old May 22, 2008 | 04:29 PM
lilmarc1988
o ok. i thought it was u from over there
Old May 22, 2008 | 04:34 PM
ZW99GT's Avatar
ZW99GT
What heads/valves do you have? You have have some clearance issues.
Old May 22, 2008 | 04:43 PM
black35th's Avatar
black35th
Kinda sounds like some PTV contact to me.
Old May 22, 2008 | 06:01 PM
FastGT's Avatar
FastGT
These are stock heads and valves, the car idles fine and everything
Old May 22, 2008 | 06:28 PM
defconfire's Avatar
defconfire
it could be the same problem i was having with my stage 1's it ended up just being some slack in the timing chain... I took it apart and re-assembled it 4 times in 5 days.[:@]
Old May 22, 2008 | 11:32 PM
blackstallion666's Avatar
blackstallion666
iv'e seen this before sounds just like what happened to me one time. Are shop sent heads out to be cleaned and inspected. once we got the heads back and installed them. It made the same noise. the problem was that the oil ports on the head for the timing chain tensioner where blocked. the shop had installed new plugs in the oil gallie ports to the tensioner, not knowing that they were blocking an oil feed for the tensioner's. sound just like a dry lifter.
Old May 23, 2008 | 06:04 AM
FastGT's Avatar
FastGT
Hey guys, just to let you know its ptvc. We were cheking the combustion chambers again with the wire camera and found that the intake valves were hitting but only on the drivers side. We are doing a compression test today to see if everything is ok. We also found that the cam for that side was off timing by one tooth in the cam gear. We will be working on it this weekend. Ill let you know how the compression test comes out
