what should I do next?
Old May 24, 2008 | 02:54 AM
40thGTKB's Avatar
40thGTKB
Default what should I do next?
im on the fence on what to do next with my car. maby you can help me decide.
I want to do gears (4.10's), however, they are no good to me when I am taking a turn at 30 MPH and my car starts to act like its on ice. So what about suspention? What do I need to take some pretty nasty turns without loosing the back end? (other than good tires, wider tires, etc)
Old May 24, 2008 | 06:38 AM
iraziel's Avatar
iraziel
Default RE: what should I do next?
ORIGINAL: 40thGTKB
Taking turns at 30mph,you dont have any decent suspensionand running 4:10s? Sounds like an accident waiting to happen...
Slow down, then look into suspension...
Old May 24, 2008 | 06:47 AM
H0SS302's Avatar
H0SS302
i can take 90 degree turns pretty well going about 35-40 in the vert( just messing around, not on a daily basis) all i have is bullitt shocks/struts, roush lower c/as, and some kdw's, subframes and a STB.
Old May 24, 2008 | 07:11 AM
jmac72187's Avatar
jmac72187
corner carver
The biggest thing is goign to be a Panhard bar. It will keep your rear centered.
Other things to look into are shocks/struts, subframe connectors, LCA's, tubular A k member, coil-over set up and some nice tires.
Old May 24, 2008 | 07:16 AM
iraziel's Avatar
iraziel
ORIGINAL: H0SS302
With those, how does it handle around those corners? Does the end break loose, or are you able to hold the road the whole corner?
