do i really need a t/b an plenum?
Old Jun 4, 2008 | 06:05 AM
inkedup75's Avatar
inkedup75
Default do i really need a t/b an plenum?
is this really a need? doin some reading on here an some say it really makes no diff, i have an intake on it know. BUT i do plan on ordering a wet kit for a 100 shot an the window switch. do you need a wot switch also? thanks
Old Jun 4, 2008 | 02:16 PM
02 Ninja's Avatar
02 Ninja
Default RE: do i really need a t/b an plenum?
You will get a little better throttle response with the TB & plenum. If you're gonna spray, then yeah you should get a WOT switch.
Old Jun 4, 2008 | 04:26 PM
steve0914's Avatar
steve0914
yes i felt a little gains from my t/b and plenum, but you def. get better throttle response....i would buy a WOT switch so you dont have to hold the button down
Old Jun 4, 2008 | 04:48 PM
SilvrStang's Avatar
SilvrStang
TB and Plenum with intake combination is a great mod. Def noticable!!!
Old Jun 4, 2008 | 11:54 PM
stacy532's Avatar
stacy532
i like mine made it feel new again
Old Jun 4, 2008 | 11:59 PM
Adam03GT's Avatar
Adam03GT
Every little bit adds up to a big difference.
Driving a stock one after mine the stock feels like a turd.
After you install a tb/plenum you definately feel the throttle response and it feels better up high in the rpms.
Old Jun 5, 2008 | 12:06 AM
Sxynerd's Avatar
Sxynerd
Garbage in / Garbage out... You get out what you put in...
Old Jun 5, 2008 | 03:01 AM
1vryfststang's Avatar
1vryfststang
You will def notice some in the higher rpm range as well as throttle response....I did! I want a intake manifold as well. I think I am going to just go with the trickflow because they make pretty nice parts...although there is alot of companies that make them....oh and one more thing since you do have an intake manifold aftermart, odds are inlet to it is 75mm therefore with a 75mm TB and everything being the same size I would not see why it would not help the air flow in its journey...or at least thats what I think! What kind of intake manifold do you have or do you just have the upper intake plenum?
JonnyBlazeGT
Nov 3, 2015 01:10 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
GimpyHSHS
Sep 18, 2015 12:27 PM
GimpyHSHS
Aug 29, 2015 06:30 PM
Gary Ugarek
Aug 26, 2015 08:41 AM
