car bogging off stop lights
Old Jun 10, 2008 | 09:03 PM
  #21
SVTBill's Avatar
SVTBill
Default RE: car bogging off stop lights
ORIGINAL: black35th
ORIGINAL: SVTBill
thanks for the info guys. it's kind of a buck, but feels more like a trailer pull.
00blackstang. no cars will even start, let alone run without the MAF plugged in.
Yes they will, my car started and ran for a few miles after I put my CAI on and forgot to plug it in. It ran like **** but it definatly ran.
i've tried starting three seperate cars with no MAF plugged in and they were all a no-go. maybe you got lucky, but it doesn't happen often.
david, have you bought any diapers and bottles yet?
brian, yes you are right
anyone else have any ideas?
Old Jun 10, 2008 | 09:20 PM
  #22
blackonblacksls's Avatar
blackonblacksls
switch out the front 02s with the rears... The rears actually dont do much at all except for keeping tabs on the cats... its the fronts that really screw things up when they go bad.
Old Jun 11, 2008 | 10:18 PM
  #23
socool9004's Avatar
socool9004
my car does this too, but only on hot days. usally it does it when i hear my cooling fans are on. just my .02, if we can figure out what is causing this it would help me too.
Old Jun 14, 2008 | 07:58 AM
  #24
bolt.com's Avatar
bolt.com
ORIGINAL: rezarxt
This might be kind of obvious, but my car bogs down when I leave T/C on and spin the wheels (duh). You sure youre not spinning the tires and having tc activate? I dont know figure Id throw it out there lol...
+1.....I find the same..........leaves you feeling like your cars a dog.........turn off the TC however...............[sm=icon_rock.gif]
Old Jun 14, 2008 | 02:16 PM
  #25
blackonblacksls
ORIGINAL: socool9004
That right there is actually your coilpacks... They are close to going out and you only have the problem after they heat up and are not firing right... Makes it a bitch to diagnose because the problem is not always there and half the time you try to explain it to someone the car is not doing it.
Old Jun 14, 2008 | 05:03 PM
  #26
SVTBill's Avatar
SVTBill
well, i just changed my plugs and it's still bogging. maybe the o2s? are front and rear o2s excatly the same, and all i have to do is switch them? it's that easy?
Old Jun 20, 2008 | 03:14 AM
  #27
socool9004's Avatar
socool9004
have you had your clutch changed recently? i found out my cars cluth is chatterig.....back to pep boys i go!
Old Jun 20, 2008 | 03:17 AM
  #28
socool9004's Avatar
socool9004
all my COP? now im worried, how do i figure out which ones are bad!
Old Jun 20, 2008 | 07:42 AM
  #29
GodAmGT00's Avatar
GodAmGT00
I honestly don't think your O2's are to blame, at all.. Regardless though, an O2 sensor is a type of thermometer, in a matter of speaking.. Cleaning them is about as useful as taking a dump without toilet paper..How's your gas mileage??
Do you have a K&N, or have you checked your air filter for debris?? It almost sounds like you may have a vacuum leak, but normally idle would be affected by it.. You may want to check your COPs for resistance with a decent Volt meter.. I don't know their threshold, but I'm sure someone on here knows off-hand...
JT
Old Jun 20, 2008 | 10:46 AM
  #30
Lombardo05's Avatar
Lombardo05
my car used to do it really bad when i bought it but only when i hit like quarter tank of gas. found a TON of rust in the gas tank. so i replaced the tank and pump. all good now
