CLEANING MY MAF SENSOR
Old Jun 26, 2008 | 12:55 PM
Redfire UFO's Avatar
Redfire UFO
Default CLEANING MY MAF SENSOR
hey guys my car was studdering a little at idle and dropping down to low rpms.... i was told to clean my maf sensor....
does anyone no how to do this without messing anything up....
thank you for any knowledge
Old Jun 26, 2008 | 01:29 PM
MustangMan00's Avatar
MustangMan00
Default RE: CLEANING MY MAF SENSOR
try the IAC (idle air control) as well, id do that first
http://www.moddedmustangs.com/wp-con...-valve-4-6.jpg
theres a pic of what it is, get some brake cleaner or MAF cleaner from the parts store, take it off with 2 8 mm bolts spray it a good couple times. disconnect the battery for 5 min or so, then put it back and start it up, let it idle and reset itself
jopefully that helps
-Pat
Old Jun 26, 2008 | 02:00 PM
baino's Avatar
baino
to clean the MAF, all you really have to do is spray off the interior components with MAF cleaner or Electronic cleaner.
Old Jun 26, 2008 | 03:17 PM
jwarner0297's Avatar
jwarner0297
Be careful with it when you clean it
Old Jun 26, 2008 | 05:20 PM
white venom's Avatar
white venom
baby poop
buy a bigger maf
Old Jun 26, 2008 | 05:21 PM
jeed64's Avatar
jeed64
ORIGINAL: white venom
buy a bigger maf
NO GILBERT!
but umm... just use MAF Cleaner and spray a bit of it on the 2 prongs and it dries up pretty quickly then you may wanna check your IAC and might wanna clean that.
Old Jun 28, 2008 | 09:54 PM
SilversurferV6's Avatar
SilversurferV6
i have the same prob, where is the iac located??? i have an 05 gt btw .....
Old Jun 28, 2008 | 10:07 PM
baino's Avatar
baino
try google. They show pics
Old Jun 29, 2008 | 10:11 AM
avexhype's Avatar
avexhype
QUESTION: what kinda of tool do i have to use to separate the mass air sensor from the housing? Its a star-shaped bolt but i couldnt use my star-driver cause it has a little bulb in the middle of the bolt head that wont allow the star-driver to insert all the way.
Old Jun 29, 2008 | 03:32 PM
white venom
baby poop
ywH TURNS out it was just a stupid vaccum leak
