nitrous
Old Jun 28, 2008 | 08:31 PM
jvog's Avatar
jvog
Default nitrous
I tried the search function first but it still doesn't work...im just curious as to how safe nitrous is on a stock 2002 gt motor...if you only run a 75 or 100 shot will it wear down the motor significantly aka shorten its life...any info would be appreciated thanks
Old Jun 28, 2008 | 08:39 PM
99mustanggt's Avatar
99mustanggt
Default RE: nitrous
No you should be fine with a 75 or 100 shot.Just be sure to have it tuned and run the safety switches to insure nothing goes wrong.I just hooked up a 150 shot to my stock motor but I'm having problems with my tuner so I haven't got to run it yet,but there are plenty of people on this site running up to a 150 with no problems.
Old Jun 28, 2008 | 10:30 PM
02 Ninja's Avatar
02 Ninja
Default RE: nitrous
I wouldn't go out and spray every weekend, but you should be fine with the 75 (safe) shot. Several guys here have sprayed 100 shot and had no problems. 99mustanggt is going to for the 150 shot. I wouldn't go that far on a stock motor because the risk factor goes up. In the end, it's your car but remember that safety always comes 1st!
Old Jun 28, 2008 | 10:52 PM
oldskool04's Avatar
oldskool04
Default RE: nitrous
i dont mean to steal the thread but i have been told i will need to rebuild the motor every 2 years is that true
Old Jun 28, 2008 | 11:48 PM
jvog's Avatar
jvog
Default RE: nitrous
will a motor running 75 or 100 shot still be capable of lasting like 120k miles
Old Jun 29, 2008 | 07:40 AM
johnr2001gt's Avatar
johnr2001gt
Default RE: nitrous
you dont need to waste money on a tune for a 100 shot or less. run colder plugs and pull a little timing out.
Old Jun 29, 2008 | 08:03 AM
contentsunderpressur's Avatar
Default RE: nitrous
ORIGINAL: johnr2001gt
+1. I ran a 100 shot for a year without pulling any timing out on a stock engine with no problems and no tune. Just run a window switch and set it to turn the gas on at 3,000. You ask how strong are the stock motors? After I ran the nitrous for a year I put the procharger on and ran it for another two years. I over-reved it and burnt a valve finally. When I tore the engine down the rotating assembly was still in great shape.
Old Jun 29, 2008 | 11:50 AM
01GT4.6's Avatar
01GT4.6
Default RE: nitrous
ORIGINAL: oldskool04
no, not true. I ran a 'big' 100 shot on my stock motor for 5 years and at 121k miles it ran like a top, never burned oil and looked very clean when taken apart.
Old Jun 29, 2008 | 12:16 PM
steve0914's Avatar
steve0914
Default RE: nitrous
i wouldn't rune more then a 100 shot, thats like 12 hp per cylinder
Sandmanbjj
Aug 21, 2015 12:38 PM
mstngdvr17
Dec 25, 2003 04:55 PM
jhogan2424
Nov 5, 2003 08:51 PM
67gt500
Aug 17, 2003 04:01 AM
