Engine troubles?!?
Old Jun 30, 2008 | 10:07 PM
v8mustang man's Avatar
v8mustang man
Default Engine troubles?!?
I have a 1998 V8 4.6L gt automatic mustang and love it. On the other hand when I gun it I get much less power out of it than I might think. It is almost the same as my van. Is their anything that could be broken or worn down that could lower the power of the car. It seems to run fine but just is not pushin out as much power as I believe it can.
Old Jun 30, 2008 | 10:12 PM
jvog's Avatar
jvog
Default RE: Engine troubles?!?
those older 4.6s were kinda slow stock...
Old Jun 30, 2008 | 10:32 PM
blackstallion666's Avatar
blackstallion666
is it stock becuase the early 4.6l (pre 99) where kinda slow.
Old Jul 1, 2008 | 12:14 AM
mustangcat's Avatar
mustangcat
Deputy CatDog - To Purr'tect and Explode
To the OP:
Do a Heads/Cams/Intake Swap on your car with a Newer Mustang GT. See, Pre-99 Mustangs are known as Non-Performance Improved, because of the restrictive H/C/I. Swapping out those parts should prove a solid 60+ Horsepower Gain.
Not bad for parts you can find in the Junkyard, eh?[8D]
Old Jul 1, 2008 | 01:31 AM
black35th's Avatar
black35th
ORIGINAL: mustangcat
To the OP:
+1
A PI swap should truly be your first mod in a 96-98.
Old Jul 1, 2008 | 01:59 AM
rambler65's Avatar
rambler65
Does that apply to 96-98 cobras or just GT's?
Old Jul 1, 2008 | 02:04 AM
black35th's Avatar
black35th
Just GT's.
Old Jul 1, 2008 | 02:32 AM
mylongvictor's Avatar
mylongvictor
Why stop at just P.I.? Why not just go ahead and get the whole set up with stage II Heads, Stage II Cams, and Trickflow intake?
Old Jul 1, 2008 | 06:34 AM
contentsunderpressur's Avatar
ORIGINAL: mylongvictor
+1 Might as well. You need to change out those parts anyway so why go with stock?
Old Jul 1, 2008 | 10:02 AM
black35th's Avatar
black35th
Well yea, if money wasnt really an object then I would say f*ck stock and go with stage 2 heads, cams, and a nice intake. Unfortunatly, that isnt the case for everyone and he would be spending at least double the amount of money.
