MSD digital window switch owners
Old Jul 1, 2008 | 08:21 PM
01snake's Avatar
01snake
Default MSD digital window switch owners
who has one?
Old Jul 1, 2008 | 08:40 PM
01GT4.6's Avatar
01GT4.6
Default RE: MSD digital window switch owners
<>raises hand</>
Old Jul 1, 2008 | 08:51 PM
johnr2001gt's Avatar
johnr2001gt
I have one???
Old Jul 1, 2008 | 10:34 PM
dimebag's Avatar
dimebag
ive got one
Old Jul 1, 2008 | 10:36 PM
code3GT's Avatar
code3GT
Mustang Nazi
I had one in the Bucket
Old Jul 2, 2008 | 12:23 AM
01snake's Avatar
01snake
can you guys tell me where you have your wires hooked up too?
i ahve been having problems with mine..when i go WOT the switch will just cut to 0 for rpm's, but under easy accleration it is fine. also when deccelrating from lets say for ex. 3000 rpms at 2,100 rpms the switch will bounce around and read 400-900 rpms when its still at 2,100rpms
i have it taped in the wire down by the pcm (green wire w/ white stripe)
and power coming from the back of the radio believe it was black wire red stripe
this problem has been holding me back from sprayin for a good 3 months almost now. and i cant get it solved no place i ask[:@]i even called MSD, and got really no help
Old Jul 2, 2008 | 12:29 AM
ZW99GT's Avatar
ZW99GT
I had a similar problem to this with my ZEX digital window. In the "menu" thing you have to tell the box where you are getting the signal from. I had it setup wrong. What do your instructions say on this?
Old Jul 2, 2008 | 12:30 AM
blackonblacksls's Avatar
blackonblacksls
try using something you know is a solid ground and a solid power wire...
just run some wires from the battery to the msd to check, and if that fixes it then redo them.
Old Jul 2, 2008 | 08:40 AM
johnr2001gt
ORIGINAL: 01snake
I pulled my tach signal off of # 1 cop,
black wire is ground
red is keyed access/power
whiterpm/tach signal
yellow to one side of your fuel presuure safety switch if running one if not hook itto the white wire on the relay depending on what system your running
grey wire not used
Old Jul 2, 2008 | 03:27 PM
01snake's Avatar
01snake
ORIGINAL: johnr2001gt
ORIGINAL: 01snake
grey wire not used
now where can i find these wires that everyones is workin with?
