Does anyone have a spoiler template for a 2001-2004 car or perhaps if you have a trunk with the spoiler removed could you make me a stencil? It will save me $100 from the body shop if anyone can...thanks. If you can, I will email you my address and send you a SASE.
look under the trunk and you will see where the holes would otherwise have been drilled out. Or if that doesn't work and you have the wing you are going to use, put some grease or lipstick on the mounting bolts, carefully press it where you want it to go and then drill where the marks where left by the mounting bolts.
My car is electric green...only 2700 made in 2001. The job seems easy enough unless you screw it up and have to by a new lid...that would be a bad thing...
