HEEEEEEEELP
ORIGINAL: stangt88
I WAN SWAP V6 2003 MUSTANG TO 5.4 SUPERCHARGE
WHAT IO NEED TO Change ??? [&o]
You need a wiring harness, I think a whole new ecu because I know they changed the system in 2005.
You will need a new transmission. If you are a 5 speed, your t5 will explode, but if your an auto your 4r70w will explode.
You need a new clutch and pressure plate. Because the v6 one would explode if you somehow rigged it to the new transmission.
Also A new rear end will be needed because the 7.5 in the v6 will explode.
And You will need a new fuel pump because the stock one will run lean and your motor will explode.
You will need new exhaust/headers. maybe custom i dont know if anyone make 5.4l headers for mustangs.... Explode
Some other stuff might explode too so be prepaired
ORIGINAL: warriorofice
without adding any sarcasms, just buy a mustang cobra, it's the easiest, hassle free and cheapest way to get a 5.4L
edit: oh yeah, with that said 2000 cobra Rs are 55gs if ur lucky.
also, why are u posting in the 4.6L section if u want a 5.4L..
