Street/Strip suspension setup
Old Jul 31, 2008 | 04:54 PM
ddmsgtr1's Avatar
ddmsgtr1
Default Street/Strip suspension setup
I'm starting to look into some suspension, and the first place it looks like I'll start this winter is the struts and shocks. For now it's a daily driver. I'm planning on coilovers all the way around, probably from MMR. Unless someone can sway me otherwise, I'll probably end up with either Competition Engineering or Lakewood 70/30 struts up front. The rear is a different situation. What is a good adjustable street/strip shock? So far I've seen the Competition 3 ways, the Chris Alston Varishocks, and the Strange 10 ways. What's my best bet to get this car to hook?
Old Jul 31, 2008 | 10:55 PM
2000GT4.6's Avatar
2000GT4.6
Default RE: Street/Strip suspension setup
adjustables ftw. I love my strange 10 ways
Old Aug 1, 2008 | 05:24 PM
ddmsgtr1's Avatar
ddmsgtr1
Do you know if the MMR coilover kit or any kit works with them?? What are you running in the front?
Old Aug 1, 2008 | 05:45 PM
01GT4.6's Avatar
01GT4.6
I love my setup but if I had to do it over again I would have went with adjustable shocks & struts
Old Aug 1, 2008 | 11:44 PM
ddmsgtr1's Avatar
ddmsgtr1
Do any of you guys have coilovers? I've heard that they're hard to set up.
Old Aug 1, 2008 | 11:50 PM
code3GT's Avatar
code3GT
Mustang Nazi
A VERY effective and affordable street/strip set up is as follows:
Strange 10 way adj front struts and rear shocks
Fox body 4 cyl front springs
Stock 99-04 GT rear springs with dead coil cut off
upper/lower CA's...double adj to adjust for pinion angle
Weld up torque boxes and axle tubes
Remove front sway bar
If ya wanna really want it to go straight and hard...UPR rear anti-roll bar
Old Aug 1, 2008 | 11:57 PM
ddmsgtr1's Avatar
ddmsgtr1
I was actually kinda looking into getting the MM 3 link style setup w/ an anti roll bar. Shocks and struts w/ springs are just the first step. What is the benefit of removing the front sway bar?
Old Aug 2, 2008 | 12:01 AM
blackstallion666's Avatar
blackstallion666
removing the front sway bar will allow for more weight transfer to the rear wheels
Old Aug 2, 2008 | 12:52 AM
avlon06's Avatar
avlon06
ORIGINAL: blackstallion666
good for going straight, but not on a turn
Old Aug 11, 2008 | 12:17 AM
brock_07's Avatar
brock_07
ORIGINAL: 1SLO85
what do u mean rear springs with dead coil cut off
