CMS stage 2 heads and cams
Ok, I was making sure that the steering rack went through the headers. I believe it is in between the 2nd and 3rd tube... It just looks like it is going to rub a lot when we do bolt them up. I guess we will see.....
Thanks guys. Pics should be up tonight.
Looking pretty sweet.. Which intake manifold is that for, 5.4??
Call me crazy, but it looks like your timing marks moved from before the tear down, to where they are now...
Did you have to degree these cams much??
JT
JT
The first pictures of the timing marks were at at TDC, the second pictures were after we rotated the crank and the motor was at 9 oclock in safe mode.
I didnt degree the cams at all... The intake manifold is just a 4.6 pi manifold.
Yup sure did. What brand of headers did you buy? If it's a decent set you "shouldn't" have any problems with fit.
