2003 Cobra Question
I did not get any replys under the on the svt forum so I posted it here looking for one...I was looking at getting a 2003 Cobra from a guy so I ran a CARFAX on it and everything came back clean expect it said it had a "Potential Odometer Rollback" So I asked him and he said that was a mistake and it was another car...On 5/25/07 it was registered with 18,917 and on the same day at the same DMV it was registered with 49,834...I does sound kinda weird but my question is I have a 1997 Cobra and if you take apart the dash you can roll the odometer back, but I think on the 2003 Cobra it is digital electronic reading..Is there a way to rollback the Odometer if it's one that has a digital display? Thanks for reading ...peace
Thanks for the reply's...It is a private seller but he says that car fax is messed up! I just figured that you would have to kinda reset the hole computer back to 0 miles if you messed with it..
I thought the dash cluster had it's own memory in it?? But it also correlates to the PCM as well.. If that's the case, then it could've been a swap out.. Not sure why, since it wouldn't be all that cheap, even going through a junk yard..
JT
JT
Yea I thought it was a great deal of work for the average person...I think it is just a mess up. I started looking for stuff on Google about CARFAX reports not being all that accurate and have bogus claims on there. I saw tons and tons of posts from people that are raising hell at there so called "Accurate Reports" good and bad ones....I don't know.... when I go to look at it I will be able to tell if it has 50,000 miles on it..Thanks
Nov 10, 2015 11:39 AM
