Ok to actually help out a little bit, Your car stock... with a turbo will never beat a termi in more than one pass, if you run enough psi on stock internals it will blow up.. .plain and simple... termis put down about 365-380 whp stock (don't try to correct me saying they put down 390 crank, i have friends ive seen dynosheets.) your car on 10psi stock will probably not even make 380, then you have to take in account the termis superior suspension, 3.55 gears and t-56 tranny... in another words there is no way you can safely stick a turbo on your stock car and destroy termis. anymore than 10psi and you run the risk of blowing ur car up real quick.
