How powerful??
Old Sep 10, 2008 | 01:29 PM
1997Stang's Avatar
1997Stang
Default How powerful??
How quick of a car would these make my 97gt?
Stage 3 foxlake heads
Stage 3 comp cams
78mm throttle body and plenum
Underdrive pulleys
K&N CAI
BBK long tubes
Prochamber
Flowmasters 40s
Limited slip differential
3.73 gears
Centerforce dual friction clutch
Dyno tube
How quick would these make my car horsepower wise?
Thanks,
Mike
Old Sep 10, 2008 | 02:29 PM
boduke0220's Avatar
boduke0220
probably around 300 hp at the wheels and if you can drive mid 12's or soemthing.
I wouldnt make it my DD
Old Sep 10, 2008 | 03:23 PM
defconfire's Avatar
defconfire
i'll say with that setup probablly about 315 to the wheels.
Old Sep 10, 2008 | 03:29 PM
Miceleb's Avatar
Miceleb
You better ad a stall converter somewhere around 3500 to that list if you want it to work (unless you are using a manual). Ditch the 373's and go 4 10's. But I think they other guys are right 300-325 to the wheels depending on the on tune.
Old Sep 10, 2008 | 03:59 PM
SVTeeshirt's Avatar
SVTeeshirt
^ +1 to 4.10s if its N/A if ur gonna go f/i 3.55 or 3/73s
Old Sep 10, 2008 | 04:54 PM
SUP3RSTANG's Avatar
SUP3RSTANG
im surprised nobody has said this yet... that 78mm tb is OVERKILL in the highest form. its like adding a 90mm maf to a bolt on GT. go with a 70 or 75.
Old Sep 10, 2008 | 05:00 PM
myslow2002gt's Avatar
myslow2002gt
I don't think stage 3's will be enough. You should get stage 5 heads/cams.
Old Sep 10, 2008 | 08:59 PM
teej281's Avatar
teej281
4.6L Section Moderator
well also remember that with stage 3 cams that you are going to have to have the engine bored out a little bit for the valve clearance and also notches in the pistons for the same reason. and dont forget fuel system upgrades too. and got with a 75mm throttle body and plenum. and you may want to have a pi intake manifold port matched and thrown on there as well. and i would take a guess and say that you are going to make over 315. a lot of other people on this forum have stage 2 heads and cams and are around 300-315. and with your compression being a 97, you are going to be a little bit ahead of the rest. so id say between 315-335rwhp depending on the tune. and definatly go 4.10's...not 3.73's.
Old Sep 10, 2008 | 09:46 PM
1997Stang's Avatar
1997Stang
What if i got the CMS stage 2.5 cams, would i still have to get the block bored and pistons notched?
Old Sep 10, 2008 | 09:48 PM
SUP3RSTANG's Avatar
SUP3RSTANG
just get stage 2 cms, and some valve springs it will be all good lol
