Iac?
Old Sep 12, 2008 | 08:54 PM
russ98stang's Avatar
russ98stang
Default Iac?
Will the iac cause you to lose power through out driving range? (if it was bad for the smart asses)
Old Sep 12, 2008 | 09:09 PM
mustangman281's Avatar
mustangman281
Banned
No it will not.
Old Sep 12, 2008 | 09:49 PM
blackstallion666's Avatar
blackstallion666
All your IAC is going to do is control idle speed.
Old Sep 12, 2008 | 09:57 PM
mustangman281
Banned
Wrong! The IAC does not control idle speed your computer does. The IAC is there to keep the engine from stalling during sudden TB blade closure and it warm the engine faster during cold starts.
Old Sep 12, 2008 | 10:04 PM
Stevecooper's Avatar
Stevecooper
no it does more than that, but that's its main function.
blackstallion666
Do you really know how an iac valve works???? And just so you know the pcm controls the iac. And what does iac mean " IDLE AIR CONTROLER". When the TB is closed the iac opens to allow air to still enter the engine. The pcm controls how much the valve is open to control idle rpm.
Old Sep 12, 2008 | 10:05 PM
Stevecooper
Are you having problems with you car?
and they are correct it won't cause a power loss when driving the car.
Old Sep 12, 2008 | 10:06 PM
blackstallion666
Also when the a/c is on the pcm opens the iac valve even more to compensate for the increased load on the engine. sorry for lashing out in your thread russ98stang , but are you having an issue with your car?
Old Sep 12, 2008 | 10:08 PM
Stevecooper
Do you know what dashpot is? the IAC takes part in this process as well.
You can alter the decay rate which is what happens when you lift of the gas. Thats why some people (I won't do this) put a plate in front of the IAC so the motor comes to an idel faster after you rev the engine.
Old Sep 12, 2008 | 10:11 PM
defconfire's Avatar
defconfire
I did that when a local tuner F*cked up my tune and it was Idling after 2200 rpm. I only did it as a temp fix.
