Thinking about Cams
Old Oct 5, 2008 | 09:12 AM
UmX's Avatar
UmX
Default Thinking about Cams
well i was looking at these. i know i need some valve springs.. and my car is a 01
anything else i really need
http://www.cushmanmotorsports.com/in...ca17de8961b753
Old Oct 5, 2008 | 09:14 AM
SUP3RSTANG's Avatar
SUP3RSTANG
i would get hitech stage 2 na grind and some cam springs from cushman lol
Old Oct 5, 2008 | 09:31 AM
sstang's Avatar
sstang
All of hitech's cams have a .550/.500 lift. I thought for that you don't need aftermarket valve springs? Maybe I'm wrong or it's a mistaked. ???
Their stage 3 only recommends springs.
Old Oct 5, 2008 | 09:34 AM
steve0914's Avatar
steve0914
i say pm the guy from cushman on here and ask him what he thinks, tell him your goals
Old Oct 5, 2008 | 09:38 AM
SUP3RSTANG's Avatar
SUP3RSTANG
i would get em anyways.. its only like 200 bucks more for no headaches. i just like the hitechs more because they are heavier on the intake side.. its still an ongoing battle wtih hitch vs cushman for me tho.. still havnt made up my mind 100% but im leaning more towards hitech
Old Oct 5, 2008 | 09:48 AM
sstang's Avatar
sstang
Well, the 200 bucks and bad, but they are a pain to install, or at least thats the impression I get.
And a while back, I believe I saw someone install some stage 1 cams without springs, and instead of taking the timing cover and all that off, they just took off the valve covers, unbolted the cams, and just swapped out the cams in the same positions. Can you do it like that without timing issues?
But to the OP, I think you would be happy with either CMS or Hitech, they both have had good results.
Old Oct 5, 2008 | 10:22 AM
Sxynerd's Avatar
Sxynerd
although the lift may not require new springs I consider it something necessary anytime you switch cams. Safe "cheap" insurance, stock spring are made for one purpose, longevity for it's cam application only.
Old Oct 5, 2008 | 10:42 AM
myslow2002gt's Avatar
myslow2002gt
It's actually .545" lift, but either way, you should never run that much lift with the stock pathetic valvesprings.
Secondly, I think most of you are forgetting that lobe ramp rates also play a significant role in spring fatigue rate, not overall valve lift.....
Old Oct 5, 2008 | 01:11 PM
Poisoned Pony's Avatar
Poisoned Pony
for me, it was a bit of extra insurance. The heads were already apart, might as well go with stronger valvesprings. Plus, if I go with Stage 2 cams, they'll already be done.
Old Oct 5, 2008 | 06:09 PM
mustangman281's Avatar
mustangman281
Banned
You should never take shortcuts with intalling cams. You should always degree aftermarket cams and always upgrade the springs. Aftermarket NA cams open much faster and higher. With the weak springs the the valve will float (lose contact with the follower/cam) and can ruin the cam lopes pretty quick.
Stock lift is .504 and .531 so any cams that are more then .010 lift then stock should have upgraded springs.
